Are you sure you changed the bios settings back correctly after updating? As far as I know there are no bios updates to AM4 boards that would cause it not to boot. Some AM5 boards thatβs true.I am using msi meg b550 unify.
OpenCore is stuck after bios update...
I used deepl translation
Thanks for the reply.Are you sure you changed the bios settings back correctly after updating? As far as I know there are no bios updates to AM4 boards that would cause it not to boot. Some AM5 boards thatβs true.
You may be the first to update CVE-2024-36877 security issue. I assume you have turned off secure boot and cleared the security keys? If nothing else works have you tried downgrading the bios?Thanks for the reply.
The bios setting is same as before update.
But I think the secure boot item is increasing before update.
secure boot is off, security key is clear. (my pc is dual boot with windows 11pro and cleared the security key required me to reconfigure my windows account)You may be the first to update CVE-2024-36877 security issue. I assume you have turned off secure boot and cleared the security keys? If nothing else works have you tried downgrading the bios?
I think you have two choices, wait for someone more knowledgeable to figure out what the problem is or downgrade. There is always a risk updating the bios, more so in the hackintosh community as updates can break a working system.secure boot is off, security key is clear. (my pc is dual boot with windows 11pro and cleared the security key required me to reconfigure my windows account)
I have heard that downgrading bios is risky so I have not tried it yet.
Thanks for your support.I think you have two choices, wait for someone more knowledgeable to figure out what the problem is or downgrade. There is always a risk updating the bios, more so in the hackintosh community as updates can break a working system.
It could be quite some time but obviously your choice.Thanks for your support.
I will wait for it to be resolved.
msi motherboard users be careful not to update bios yet.
Not that I'm aware of but not every manufacturer of motherboards has this issue. It seems to be MSI boards that have the bios update problem. What is your setup, what hardware?Hello everyone, I'm having the same problem, is there any progress on a solution?
