Black Screen after Verbose
GarvitPlayz
38
AMD RYZEN 4600H
Hey guys! After booting the MacOS installer from the pendrive, it does the commands thingy and then the screen goes completely black. The system is on and working, since I can turn on narrator and it tells me the language selection options. I can't see anything on the screen itself. My System Specs are - Ryzen 5 4600h, Gtx 1650ti(Disabled), HP Laptop. I have narrowed it down to probably my serial port being enabled. The main problem now is, I cannot disable the serial port, since my bios has no option to do so! Is there any other alternative method to achieve this? My EFI Folder is linked below.
Using Nootedred? Did you add the files for the backlight? Uploading your EFI would help. Serial port being disabled wont affect the image displaying.
Have you tried connecting a separate display to your laptop to see if the login screen etc. shows?
I have an Asus AMD laptop that refuses to show the macOS login screen on the built-in display, but shows it on an external HDMI connected display.
My TV gets installed tommorow. I'll check then and tell ya
Also guys, The screen isn't like completely turned off, it still shows that bit of greyish color which indicates it's on
I'd advise against using a premade EFI from Olarila...
I don't know which LAN chip your system uses so I've left those kexts in place but disabled them. Please enable the correct one only and remove the others. Try this EFI,
Didn't work. It showed me the apple.com/support error screen and then took me back to the OS selection screen
HEY! It is a problem with nootedred! I disabled it and it worked! But no graphical Acceleration tho :( Any fixes for that?
BTW I used the original EFI tho
Solution
I found this EFI folder online for a laptop with the same specs as me, just from lenovo(rest everything is the same, the wifi card model, the ethernet model and everything)
You think this would work?
