Why do you assume they wouldn't? When it's been made for every macos version until now......i think you need to wait for a long time........i don't think someone make this kext directly suitable for sequoia...but...maybe..
'couse seems zxystd leave macos resources for develop only kotlin for harmony-os and he have no time for kextWhy do you assume they wouldn't? When it's been made for every macos version until now...
..for this i assume that.I don't understand what you mean sorry? What's Harmony-OS?'couse seems zxystd leave macos resources for develop only kotlin for harmony-os and he have no time for kext ..for this i assume that.
Thanks, but I'm confused, why am I running OCLP on a hackintosh and applying root patches?AirPortItlwm.kext work on Sequoia 15.0.1 this
Maybe better Airportitwlm.kext place under FamilyLegacy.kext in PlugIns and remove AirPortBrcmNIC.kext.
It is your right to wait for zxystd to be released. If you work on Sonoma, you don't need to worry. If you have Sequoia and need the Iphone screen mirror function and use a standard WiFi client, see the link to the instruction above more carefully.Thanks, but I'm confused, why am I running OCLP on a hackintosh and applying root patches?
Why does it say to use the Ventura airportitlwm instead of the Sonoma one? Surely I can just use my Sonoma kext instead of an older Ventura one?
Does this require having SIP disabled? If so I'd rather just wait for a proper kext.
Yeah Sonoma 14.7 is flawless on this buildIt is your right to wait for zxystd to be released. If you work on Sonoma, you don't need to worry. If you have Sequoia and need the Iphone screen mirror function and use a standard WiFi client, see the link to the instruction above more carefully.
Huawei operating system. and zxystd , for now , only work with this...maybe they can update kext on 15.1 release...didn't know :-\I don't understand what you mean sorry? What's Harmony-OS?
you need to add fake id to your intel card so OS see it has brcm4360 chipset instead intel..Thanks, but I'm confused, why am I running OCLP on a hackintosh and applying root patches?
Wow, that's very stupid to just drop the support for macos to mess round with a rubbish phones OS! What a traitor lol!Huawei operating system. and zxystd , for now , only work with this...maybe they can update kext on 15.1 release...didn't know :-\
after that, you need to use OCLP for add support for brcm4360 (fake one), to Sequoia
No, you need ventura's one 'couse Sonoma's kext is modified and in this case, didn't work
absolutely yes, you need a partial SIP disabled for this procedure. (where's the problem?)
Hello, I tried that oclp fork, but it doesn't work, I already installed the kext, I reset the nvram and it doesn't activate the wifiIntel WiFi and Bluetooth work perfectly with the native Sequoia driver. Currently, we are using the OCLP patching method.
You can download the Intel-specific OCLP patch here: https://www.simplehac.cn/forum.php?mod=viewthread&tid=53&extra=page=1.
For a reference tutorial, visit: https://www.bilibili.com/video/BV1r...ck&vd_source=4c08bd424b9fa9d439d6b9d21549efb7.
It's best to start your own theadHello, I tried that oclp fork, but it doesn't work, I already installed the kext, I reset the nvram and it doesn't activate the wifi
