Unable to get my PC Hackintoshed
ready2000
12
RYZEN 5500GT
Well, First let me show my specs:
Ryzen 5500GT APU (It's just Ryzen 5600G but a little higher turbo speed; no difference)
RTX 3050 8GB INNO3D, ofcourse it can't work so I have added -wegnoegpu
MSI MAG MORTAR MAX WIFI B550M Motherboard
EVM M.2 NVMe (2280) 512GB Internal SSD​
16GB RAM
Now, I am trying to install macOS Sequioa for my PC, but am getting error as shown in the SS1 photo.
My EFI folder with config is attached that gets me to the kernel Panic in SS1.
According to Dortania guide, i tried everything and that EnableWriteUnprotector on + 2 things off and vice versa but no luck. :(
I have made EFI from scratch using the Dortania guide. No luck.
I have added NootedRed as i need to use my iGPU.
I have tried with Sonoma, Sequioa, Ventura and Monterey, none of them boots. Please help.
I have changed my BIOS Settings and I dont think aanything is wrong there.
  • EFI2.zip
    EFI2.zip
Solution
Okay guys so.... I really thank all of you for the support, I have solved the issue and now macOS is running very very well.
I removed all SSDTs and added SSDT-EC-USBX-Desktop and SSDT-PLUG-ALT
This booted my system perfectly and everything installed perfectly.
(I got this answer for EliteMX86, but you all guys helped a lot too. I thank all of you for your support)
Your're using the wrong SMBIOS for NootedRed, in the EFI attached to #1 you have MacPro1.1. NootedRed is only compatible with MacPro7,1 or iMac20,1 or 20,2.
pls check latest efi, it's imac20,1 only and nootedred disabled i attached here also in my previous replies it was there
Yes, NootedRed.kext supports 'Cezanne' CPU's and GPU's. My Ryzen 7 5700G is a Renior/Cezanne mix and works really well with the kext in Sonoma and Sequoia.
The screenshot below shows the Hackintool > PCIe tab, with the APU highlighted.
Screenshot 2024-09-29 at 16.35.59.png Hackintool > PCIe tab
This screenshot shows the Cezanne GPU driving 2 x Dell Displays both set at 2560x1440 resolution
Screenshot 2024-09-29 at 16.37.24.png System Information > Graphics/Display report
Reactions: leesurone
The OP's issue could be related to the NVME M.2 drive being used. The EVM M.2 NVMe (2280) 512GB Internal SSD contains/uses an SM2263XT GenIIIx4 controller. I have no clue as to whether this controller is supported in macOS. The Controller is from SiliconMotion.
EVM NVME and Controller data sheets are attached.
Reactions: etorix
Nice, I mentioned that to him over at TMX86 but found less information. Seems like its worth trying a different drive
That would be my first instinct with this system. As the manufacturers tend to install drives that work with Windows &/or Linux, not macOS.
Reactions: slead
Solution
