Screen flickering with cursor randomly
Is there any other way to resolve this issue? I don't want to downgrade to Big Sur
Buying an AMD Supported graphics card, otherwise no, OCLP is your only option.
Reactions: natenyc
You need to have SIP set correctly for it and the select Post-Install Root Patch. If I recall the value for SIP (csr-active-config in your config) is 02080000
OCLP will detect your legacy Nvidia card and know what to patch.
Shouldn't SIP be set to 03080000 when using OCLP?
@Edhawk Possibly, I couldn't recall. Upon opening OCLP it'll tell you the required value that needs to be set though.
Can you elaborate on how it's not working? Any errors or screenshots of it?
