help for install sonoma on rayzen 5700x
appflowstudio
Rayzen 5700x
Hello processer 5700x
gpu 570rx 8gb asrock
32 gb ram
b550m msi motherboard
500 p3 plus nvme
need efi file please help to install sonoma with opencore
Have a look at these Success Stories for similar B550 systems. You should be able to use one of them as a base to create your own EFI.
Sure, I will post a copy of my current OC EFI when I am next at my desk (later today).
Here is a copy of the EFI I use with my Asus X570 system. I use OpenCore Release 1.0.5.
  1. I have amended it to match your system which uses the RX 6900 XT.
  2. I have removed any entries for system specific components that I use, this includes:
    1. Aquantia 10GB Ethernet PCIe adapter
    2. RX 6700 XT
    3. Broadcom BCM43602CS WiFi /BT PCIe card.
  3. I don't use the Built-in Intel i211-AT 2.5GB Ethernet controller/port
    1. I have added AppleIGB.kext to the /EFI/OC/Kexts folder and enabled it in the config.plist.
Testing/Booting:
Assuming you want to try this EFI, simply add your Serial Number, MLB, ROM and SystemUUID data to the config.plist.
I would recommend using Corpnewt's ProperTree plist editor (can be used in macOS or Windows) to make any edits to the config.plist.
Don't make any other changes to the setup.
Copy the EFI folder to the EFI partition on your macOS installation drive, or to a spare USB pen drive and boot from the pen drive to test the EFI.
Don't replace your current EFI (if you have bothered to create one) until you are sure the revised EFI works and boots without any issues.
You will need to use the ResetNvramEntry.efi option before you boot with this revised OC setup.
  • Simply boot from the USB pen drive, press the Spacebar when you arrive on the OC boot screen (GUI),
    • This will unhide the tools and drivers contained in your OC setup.
  • Select the ResetNvramEntry.efi and the system should automatically reboot.
  • Select your USB pen drive from the system Boot Menu again, and
    • This time boot in to macOS using the EFI.
crossy road
I would like to know if I need to perform any additional steps after using the ResetNvramEntry.efi option before I boot into macOS with the revised EFI?
I have an MSI B550M, and have never had to use ResetNvmramEntry.efi for anything, even when replacing multiple EFI folders after changing things :)
No you don’t need to do anything else after using ResetNvram, as long as your system boots the correct drive for OpenCore.
