Crashes messages on first boot
miketr
Amd Ryzen 5 2600
Hello. I am new here. I tried to install the macos 14 on my pc. I followed some tutorials. I installed the macos completely but when I try to boot the Mac os drive for the first time (to go to the screen that you should input account name password etc for register) I get some crashes errors. Here is an image that includes these messages.
Did it happen on anybody?
My pc:
CPU: AMD Ryzen 5 2600 (6 cores 3.4ghz)
GPU: Nvidia GeForce GTX 1660 Ti
Ram: 32gb
**I installed the macos on a USB stick 3.2 256gb
Solution
My pc:
Ram: 32gb
Unfortunately your GPU is not supported in any version of macOS and there is no iGPU on your CPU. You would need to purchase a supported AMD Graphics card to be able to install.
My pc:
Ram: 32gb
Solution
