Before USB mapping, there is renaming
joel.yank
6
Hello everyone, I have been running my Ryzentosh for a while now to be comfortable enough to try the dark arts of USB Mapping, as from IOReg I could tell I am missing at least 2 ports.
In the System Preparation part of USB mapping, they tell us to rename our controllers first (my SMBIOS requires it, spec details below) by patching the ACPI part of config.plist. I did so accordingly and the whole thing fails to boot, getting past only the bootpicker of OC. The failure message is:
00:000 00:000 OC: ACPI patch 2 is borked
Patch 2 is the patch that I have added for the renaming, and I have obviously enabled the patch here.
Am I misunderstanding the instructions here? Should enable the patch after the whole remapping process is done?
Specs are below:
AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor
Gigabyte X570 AORUS PRO ATX AM4 Motherboard
Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory
Intel 660p 1 TB M.2-2280 NVME Solid State Drive
XFX Radeon RX 5700 XT 8 GB THICC II
iMacPro1,1
Catalina 10.15.6
OpenCore 6.0
Reactions: VenimK
Share the patch you've used. You've entered something wrong hence the borked message.
Reactions: Shaneee
This is what my System uses now. No issues with USB and Windows boots fine with OC.
is this fix. apci error when boot windows from opencore
