Someone please help me im loosing my mind - [EB|LOG:EXITBS:START]
om-knof 3D
14
Ryzen 7700x
If anyone is reading this i would like them to help me.
I have this error on my first hackintosh.
[EB|LOG:EXITBS:START]​
Specs: RYZEN 7 7700x, RADEON RX 6800XT, GIGABYTE B650 GAMING X AX
Heres my Config.plist:
Solution
Check this out in success stories, same board. I updated his EFI so it should load Sonoma, changed the CPU score counts to 8 too.
The config.plist only tells half the story. Please zip and upload your entire EFI folder for help.
Solution
thank u i will try it now
Quick update: I have the custom opencore boot menu now, but when i click on the usb (dmg) nothing happens its just pitch black and kicks me out 10 seconds later
I'm not exactly sure what you mean. Maybe post a photo of what you see? I am guessing you haven't built the USB install drive correctly but from the information provided its impossible to tell.
Stolen from Edhawk
Try remaking your macOS Installation drive/app, as it could be your installer is borked.
  1. Erase the current macOS Installation drive.
  2. Delete the macOS installation app you previously downloaded.
  3. Download a new copy of the Sonoma installation app.
  4. Format your USB pen drive as HFS+ with a single partition in Disk Utility, name the drive 'USB'.
  5. Use the following Terminal command to restore the app to your USB installer.
    1. sudo /Applications/Install\ macOS\ Sonoma.app/Contents/Resources/createinstallmedia --volume /Volumes/USB /Applications/Install\ macOS\ Sonoma.app --nointeraction
  6. When the installation has completed, quit Terminal.
  7. Copy the EFI folder from @lessurone to the EFI partition on your USB installer.
Stolen from Edhawk
I will send you a screenshot of whats going on tomorrow since its 1:50 am
Stolen from Edhawk
Heres a picture,it doesnt have EFI boot on the picker,yes i pressed space
Also doesnt it need to be EFI boot, then pick ur OS?
Your USB drive is not set up correctly, if done right at boot it will show an icon of the version of macOS you are installing and say InstallSonoma or some such label.
I mean what do i do to fix it*
From the post above
From the post above
How do i format it as HFS+? And how do i do the sudo/ commands if im on windows
i already did this 2 times and its still not doing anything
I already did this and it didnt do anything
Well I'd have to guess you didn't follow the instructions properly, I've never done this myself so I can't really help except to suggest to start over and take your time reading the instructions.
Hey, i just took this photo on the startup of the pc. Could this mean something?
As long as OpenCore kept loading, no it’s normal.
