Problems with OpenCore Boot
Raphael
15
AMD Ryzen 5 5600G
I tried everything, read and read again the guide, I do all steps again and again, but everytime the same error
Specs:
Cpu ryzen 5600G family 19h zen
Motherboard B450M V2
Bios updated 03/08/2022
16Gb ram dual channel
My pendrive have two partities
How did you get on with the EFI folder I provided in post #6 in your previous High Sierra thread?
Reactions: Raphael
Oh…Edhawk I only read one thing em
“You shouldn't need to do anything or change the EFI contents.”
I followed the tutorial and changed the efi 🤦🏻‍♂️
Let me try again and return here
Well when start rn, open this screen(See attachments) if I don’t click in anything start Win11 and if I click, start win11 too
If it's the installer you're booting press the space bar to see it. HideAuxiliary is probably enabled.
Reactions: Raphael
Now have this
Specs:
and about the resolution, like this, cutting some letters, have a way to change it?
Your USB is wrong then if the installer isn't showing. As per Dortania guide on Windows it should all be on one partition,
Reactions: Raphael and Edhawk
I solved this, but have a new problem rn, I think I see this in dortania guide problems solutions, let me see if is the same error
Edit: This appear, when i click in the engine for install MacOS this appear, i can progreed more, I wait more than 30 minutes and no change nothing
I see dortania guide, not about this problem, i'm going try start again and wait this white messages, idk if this is one true error, I only posted because stucked and only show errors
Edit:Really stucked in this white letters
Updates:
I tried to do again a lot of times, and everytime the same error, Idk what do more to solve this problem, I tried more than four times, do and redo the usb, see the guide a lot of times to see if I can do something to solve this problem.
Another option is to download a premade AMD VM image. Create the installer USB using createinstallmedia as outlined in the Dortania guide for creating the USB in macOS. It does mean more downloading though but it's the "official" way to create the macOS installer.
