I recently attempted a new clean install of Catalina, but got blocked after the successful install and first run setup. When the system does is final first boot into the OS, I get a system panic and reboot faster than I can capture the verbose logs. I have been investigating a more detailed way to drill into the trigger for the issue, but my system scrolls so fast that even my gopro can't seem to capture the last lines on slow video (literally between screen refreshes, so it is very fast).
I am able to recover and boot from a backup drive, but I am trying to find out if there is a way to use the command line "log show" commands to provide a log summary the way you can for your active boot drive, but on my "failed" now external disk. The logs I find don't appear to be that helpful and dmesg only shows the current system buffer (of course).
Do I need to swap out my OpenCore for a debug version?
I am using OC 0.5.9, Mac OS X Catalina fresh install 10.15.6
