Hi all!
I have this build working fine for macOS Ventura (using the latest version 13.6.5)
The BIOS was updated to F22b.
I wanted to install Sonoma because most of the times I put my hack to sleep, it shuts down and it drives me crazy. I don't want to leave the pc always on when I'm not using it.
The problem is: the attached EFI boots successfully Ventura (and Ventura Install Disk) won't boot Sonoma at all - even after adding the boot arg
I also changed:
The issue is this one, it happens in the start of the open core boot:
The BIOS is probably correctly set (as it works fine for Ventura):
I already tried all these methods:
Every methods results in the same initial boot error...
Any help is highly appreciated
Update: As Edhawk pointed out a few posts bellow, a was using old AMD Kernel Patches in your config.plist... I updated them to the latest one following dortania guide and it booted correctly into Sonoma installer :-D
Attached you can find my EFI for my setup, with Open Core Legacy Patcher patches applied (as I have the Fenvi wifi/bt board): EFI_oc099_ver32_sonoma_working_OLP1.4.3.zip
- Gigabyte B650M Aorus PRO AX (rev. 1.0) - bios F22b
- AMD Ryzen 9 7900X 12-core 24-thread processor
- TBD Radeon RX 6xxx GPU ( I had to return the 6800XT because it was crashing in games and rebooting in 3dmark spy test)
- 32GB Kingston 5600MHz CL40 DDR5 with AMD EXPO support and RGB that NEVER EVER turns off in sleep, this is killing me) (2 x 16GB modules)
- Fenvi 919 PCI-Express Wifi/BT module
revpatch=sbvmm (Kext Restrict Events).
I also changed:
Misc -> Security -> SecureBootModel: ‘Disabled’
- Fast Boot - Disabled
- Secure Boot - Disabled
- Serial/COM Port - Disabled
- Parallel Port - Not available in BIOS
- Compatibility Support Module (CSM) - Disabled
- IOMMU - Disabled
- Above 4G Decoding - Enabled
- XHCI - Enabled
- OS type: OtherOS (Standard)
- SATA Mode: AHCI
- ReSize BAR: Enabled(ON)
- Generate a full install pendrive from a intel mac (dortania guide)
- Generate a online install pendrive (dortania guide)
- Upgrade my current ventura install
