10.15.6 Catalina Mouse Stutter & Lag (Examples)
esqua10
6
I want to solve this problem.
  • Operating System: Catalina 10.15.6 (19G73)
  • CPU: Ryzen 5 3600
  • Motherboard: MSI B450 Tomahawk Max
  • RAM: 16GB DDR4 3600MHz
  • Graphics: Sapphire Nitro+ RX 580 8 GB
  • SSD: Adata XPG SX8200 Pro 256GB 3500MB/1200MBs NVMe PCIe M.2 SSD
  • Bootloader: OpenCore 0.6.0
Unsuccessful solutions
  • Single monฤฑtor​
  • Dual monฤฑtor​
  • Quality DP cable​
  • Quality HDMI cable​
Example (Apple Music)
Example (Browser)
Check your bios settings. If you have an option to set the PCIe Generation to 3 (from 4/Auto) it solves a lot of problems.
Damn, sorry to hear that. Mouse on a different port? When I run your plist through Sanity checker it says you need to add an alcid=layout boot argument, since you are using AppleALC.kext? Maybe look into that (here's a list of layout-codes) I don't use that kext so don't have a lot of advice to give.
Similar problem.
I added it directly to the Device Properties section.
Similar problem.
I am using dual monitors. How do we solve this problem ?
why are you using busratio=42 ?
I had similar problem using iMac19,x smbios, changing to iMacPro1,1 and mapping the usb fixed it
The solution is to switch to iMacPro1.1 ?
for me it was and mapping the usb, now my system even sleeps perfect in Catalina
Can someone help with with mapping my USB please
