- Joined
- May 2, 2020
- Messages
- 17
Hi
Wanted to make a follow up thread to the old archived 'SNAZZY LABS RYZENSHINE BUILD WITH ASROCK X570 CREATOR' thread for continued info on TB3 support for that board.
Latest Update:
Update #1 - Thunderbolt 3 is working albeit with some caveats - link to comment in this thread with info:
Original Post:
I'm trying to figure out why following @iGPU's awesome https://github.com/iGPU/AMD_OC_Ryzen EFI does not net me functioning TB at all.
Question: Has there been revisions to the X570 Creator which change the TB device / PCI device tree silently?
Question: What is the status of TB3 on this board?
The only major difference I can tell with hardware in our build is that I lack any BT devices at all. The system BT is disabled in bios, the SSDT to disable the internal BT is enabled - but I dont have a PCIE BT device and ive not done any module swap.
I noticed one detail in his System Info and IOReg - in his screenshots his PCI devices for the built in / PCIe TB card are 0x15D4 / 0x15EC
Mine are 0x15EA which presumably would make iGPU's SSDTs not activate since they aren't targeting the right device?
Question: Would not having an enabled BT device cause PCI addresses on the board to change? That seems crazy.
Correction:
Using IORegistry Explorer (see attached IOReg file) I do in fact see a driver at the same address - I confused the USB 3 controller in the TB3 controller for the TB3 controller. This **** is nuanced haha.
So I do appear to have the same PCI layout which makes sense however I dont see the same info in my TB3 IOReg. N
For reference: My X570 using IOReg and navigating to the same PCI device as what @iGPU posted. Also a DCPIManager screen and an attached iOReg file.
iGPUs TB Device tree from the GitHub page.
Latest Update:
Original Post:
Correction:
