I have updated opencore to 0.99 and 14.4 still does not install. The same Config.plist works correctly with Sonoma 14.1.1 and with the latest version of Ventura.
I have removed the Broadcom bluetooth kexts since they gave me errors when updating opencore to 0.99.
It still doesn't work when I update to 14.4. Does this latest update have any kind of patch?
How to Fix Reboot Loop when installing or Updating to macOS Sonoma 14.4 and Later This guide covers fixing the reboot loop when performing a clean installation of macOS Sonoma 14.4 or updating an existing version of macOS to macOS Sonoma 14.4. By following this guide, you'll be able to do a...
Isn't there a way to only show "AMD Ryzen 5 5600X" and not show "3.7 GHz AMD Ryzen 5 5600X"?
On the other hand, I haven't gotten Mac OS Sonoma to check for updates. In Mac OS Ventura it always showed me the updates but now I am on Sonoma 14.4 and it does not show me the 14.4.1 update.
That could be happening? I have opencore in its latest version and the kexts are also updated.
The same config.plist on Ventura was showing updates.
Sorry for the inconvenience I cause
Thank you so much
