install error
realguitar
amd ryzen 1600 six core
Hi, please help me, I'm trying to install hackintosh on my computer (amd ryzen 5 1600, rx 470, asus prime b350m-a) and I get an error when selecting the Install macOS Sonoma disc and the loading does not continue. I tried different EFl, did it myself and took it from the Internet, it's still such a mistake.
Post a copy of your current OpenCore EFI, so we can see what you are using and what might be causing the issues you are facing.
Hi, I have tried many different EFI's, still the same error, I think my components need additional firmware.
Your core counts were wrong, I changed them to six cores in the EFI I uploaded.
Are your bios settings looking similar to these?
AMD BIOS Settings​
  • Note: Most of these options may not be present in your firmware, we recommend matching up as closely as possible but don't be too concerned if many of these options are not available in your BIOS
#Disable​
  • Fast Boot
  • Secure Boot
  • Serial/COM Port
  • Parallel Port
  • IOMMU
#Enable​
  • Above 4G Decoding (This must be on, if you can't find the option then add npci=0x3000 to boot-args. Do not have both this option and npci enabled at the same time.)
    • If you are on a Gigabyte/Aorus or an AsRock motherboard, enabling this option may break certain drivers(ie. Ethernet) and/or boot failures on other OSes, if it does happen then disable this option and opt for npci instead
    • 2020+ BIOS Notes: When enabling Above4G, Resizable BAR Support may become an available on some X570 and newer motherboards. Please ensure that Booter -> Quirks -> ResizeAppleGpuBars is set to 0 if this is enabled.
  • EHCI/XHCI Hand-off
  • SATA Mode: AHCI
Hi, yes, the problem was in the incorrectly set processor cores. I started to install and at the end the computer endlessly reboots and such an error is grounded.
It looks like your GPU is not engaging, can I assume your bios does not have the Above 4G Decoding setting? Your config.plist boot arguments calls for npci=0x2000 unfairgva=1 alcid=11 -v debug=0x100 keepsyms=1. You can try npci=0x3000. If the bios option is available remove any instance of npci=
I don't have this function (asus prime b350m-a, bios 2020), I tried to put ncpi=0x3000 but the same error.
Here is an OpenCore 0.9.9 EFI for your B350-A/R 5 1600/RX 470 system.
See if this helps.
How long did you leave the system on that screen? As I don’t see an error. AMD systems can pause foe some time when booting the installer, you need to have some patience, especially when the screen doesn’t show an error, or kernel panic.
How long did you leave the system on that screen? As I don’t see an error. AMD systems can pause foe some time when booting the installer, you need to have some patience, especially when the screen doesn’t show an error, or kernel I've been waiting for 10 minutes, no reaction, but the fans are spinning very loudly.
