[Solved]upgrade from OC 0.5.9 to 0.6.0 will never boot
aotsuki
Guys, I met a strange problem which maybe not a config issue.. :(
I used ProperTree snapshot config.plist from OC 0.5.9 which boot without any problem.
And I followed https://dortania.github.io/OpenCore-Install-Guide/AMD/zen.html set the new config and did not changed any kexts or boot config, but it will hang at the apple logo and I got error log after using 0.5.9 boot into macos.
Error log is attached..
  • opencore-2020-08-07-110358.txt
Boot with Verbose ( -v ) and see where it hangs. The OC log won't help here as it doesn't seem to be an OC error.
aotsuki
attached config.plist
VenimK
You 'r running this on a desktop ??
aotsuki
Solved, proper tree missed a kext's execute path lead to panic at the init phase.
