Dual boot on a Ryzentosh
HKPhysicist
52
AMD Ryzen 5 5600H
Dear Experts,
Mine is a mini PC with Ryzen 5 5600H.
I plan to install a macOS 14.1 on it. Besides, I also want to install Android-x86 on the same primary SSD disk so that they form dual-boot set up.
So, I can test the newest Android apps without buying the newest phones from time to time.
Do you think whether it is possible? Please share your experience. :)
Yes it is possible.
Have a read of this old multi-booting guide using a single drive. It is old but the process hasn’t changed much. You just need an APFS container for macOS instead of the HFS+ Partition mentioned in the guide. Plus use OpenCore not Clover.
Yes it is possible.
It sounds good. Please show the guide`s URL as well. Thank you! :)
Reactions: HKPhysicist
