Ryzen 5 2600x - Aorus B450M - Sapphire rx5700xt - OC 0.5.9. Catalina 10.5.5
Nikotetfe
20
Canary Island
Build
CPU: AMD Ryzen 5 2600X
Mainboard: Gigabyte Aorus B450-M Bios F50
Memory: 2X Crucial Ballistix Sport LT Red Single Rank DDR4 2666Mhz PC4-21300 8GB CL16
Storage: Samsung 970 EVO Plus 500GB SSD NVMe M.2
Video Card: Sapphire Radeon RX 5700 XT Nitro + 8G ddr6
Power Supply: Corsair VS650 650W 80 Plus White
Case: Infinity SIGMA
Working
Audio
LAN
Shutdown
USB
Sleep
BIOS settings
CSM: disabled
Above 4G decoding: disabled
Fast boot: disabled
Deep sleep: disabled
I have a problem with the performance of the graphics card. The results with geekbench 5 are really low. I have seen in other forums where the results are twice as fast. I have tried changing smbios from iMacPro 1.1 to MacPro7.1 and have no better results. I have tried everything. I am attaching my EFI in case anyone finds the problem. thank you very much to all
Captura de pantalla 2020-06-29 a las 13.22.54.pngCaptura de pantalla 2020-06-29 a las 13.23.56.pngCaptura de pantalla 2020-06-29 a las 13.53.17.png
    config.plist
I have almost the same configuration (ryzen 5 2600, RX5700xt). Do you experience any micro-lag on your mouse?
I don't . The lag I see is related to applications. For instance, sometimes I click to open a new tab on Safari, but it freezes for one second or two. Maybe moving the OS from the SATA SSD to the NVMe will reduce this lag, maybe I just need more memory, maybe c'est la vie... Not a big deal, anyway: it happens only a few times a day.
I change the ssd operating system to nmve and in the bios I change the configuration of the pci to Gen3 and I have almost no delay
OC 0.5.9 does 'nt need the apfsdriverloader.kext ???
@Nikotetfe Since you have Windows you could try MorePowerTool to create the table.
  1. Extract the BIOS with RBE_Setup.exe
  2. Import it into MorePowerTool_Setup.exe and edit what you need then "Write SPPT"
  3. Get the table out of the registry under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}
thank you!!!! I will try it this afternoon
