Got a kernel panic trying to install macOS (Lenovo IdeaPad Ryzen 4300u)
imwrkacc
18
Trying to install macOS on laptop Lenovo IdeaPad 3 15ARE05
Specs:
AMD Ryzen 3 4300U
AMD Radeon Graphics Vega
NVME SSD 500GB
Created EFI folder by following Dortania's guide, and still getting a kernel panic, that says about something called "invalid frame pointer"
Can someone please help me fix this issue?
Post a copy of your EFI so we can see wha you are using to run macOS on this AMD Laptop.
The screen image you posted doesn't tell us much and without seeing your EFI we have nothing to go on or correct.
Reactions: imwrkacc
So, i changed a couple quirks following General troubleshooting guide about invalid frame pointer
This one:
And got another kernel panic, ever scarier. I hope it can be fixed
Here is my EFI folder. Many thanks in advance for helping!
    EFI.zip
Try this OC EFI in place of your current one, see if this works any better.
Reactions: imwrkacc
Now i'm getting this log (pic 1)
Since i followed Dortania's USB creation guide, my flash drive structire looks like this (pic 2)
So basically, my usb contains macOS recovery dmg, and EFI folder in same partition.
Should i remake my USB using macOS virtual machine, Mac App Store OS image, and createinstallmedia Terminal utillity?
Edit: Got the same result by making another one USB using macOS VM & Terminal utillity
OK, that means the EFI setup went backwards, to kernel panic at an earlier point.
I have changed the SSDT-EC-USBX-AMD.aml table for the one you were using previously, as that passed this point in the boot process.
Try with this EFI-2.zip and see what occurs.
Reactions: imwrkacc
I tried the new EFI folder, and got exactly the same result. Tried on both of my USB, w/ full installer and recovery only.
One thing to clarify, i posted this topic in 11.0 Big Sur thread, but what i'm trying to install is 12.0 Monterey. If that is important, then i'm very sorry for posting it in wrong thread, i hope we can work this out
First png seems to be caused by NootedRed.kext, make sure CSM is disabled on BIOS, and not used for OS installation.
Recently, NootedRed.kext need to be disabled for macOS fresh installation / system upgrade, re-enable it after installation or system update.
Reactions: imwrkacc
Tried to boot with disabled NootedRed.kext and got the same result. Also there is no CSM option in my BIOS, so i can't disable it
Try reset NVram, press spacebar from opencre boot menu, select Clear NVRAM reboot.
I already did this once, and Bios and the boot menu stopped opening for me, so I had to backflash the bios to make it work again.
Edit: Well, i did that, still getting kernel panic, and now BIOS and Boot Menu didn't show up, instead OpenCore menu appears
Specs:
AMD Ryzen 3 4300U
NVME SSD 500GB
Also having the same error, Ideapad 3 Ryzen 7 5700U / Vega 8. I'll be following here but if I find any fix Ill let you know.
Reactions: imwrkacc
I double checked with attached EFI (5600g and 2200g), it pass macOSs fresh install and work fine after installation, Big Sur, Monterey OK, only Ventura has cold boot issue, need boot from Monterey first then reboot to Ventura ok.
Seems to be Laptop ACPI tables are more complex than Desktop.
For fresh installation, less is better
1, use CPUR.aml + PLUG.aml + EC-USBX.aml
2, kexts use LILU + VirtualSMC
3, UEFI Quirks set releaseUsbOwnership to yes
Try attached config, also upload your current config PLS.
Tried this config with your EFI folder - got the same kernel panic. My original EFI attached to post #3 in this thread. Also i tried EFI's by Edhawk, they also attached to his messages
I edited your EFI and tested with my 5600g, it work with some kexts disabled, work fine, USB installer passed with nootedred disabled, issue seems to be cause by ACPI code, different from desktop mother board, I don't have AMD laptop, can not dump ACPI table for test.
Anyway, do one more test with attached EFI.
Thank you for your responses. Unfortunately, i got the same kernel panic as usual like in #11 post (com.apple.driver.AppleACPIPlatform(6,1)
Edit: I just created a dump, using SSDTTime and got .aml file. Maybe it can help somehow
For those interested, there is a working OC 0.9.2 Big Sur EFI build for Lenovo Ryzen Yoga 16S 7 5800H using NootedRed found here > https://github.com/zabdottler/Lenovo-Yoga-16S-hackintosh
To make it works, just make sure the settings for the Ryzen under Kernel > Patches match up with the number of cores you have in your system.
Tried this EFI, and there is no Install macOS boot option, even after hitting space button.
