Problem with boot x570 Aorus Master, Ryzen 9 3900x, RX 580
davemaster
7
Hi,
I have problem with boot. I send screenshot with stuck.
My specs:
CPU: Ryzen 9 3900x
MB: Gigabyte x570 Aorus Master rev 1.0
GPU: Asus Strix RX 580 Gaming 8GB
OS: Catalina 10.15.5
Possible error:
With GPU GTX 1080:
boot fine to installer (graphic glitch, but I know unsupported with Catalina).
*BIOS CSM disabled
With GPU RX 580:
stuck on boot (screenshot)
*BIOS CSM: I set DISABLED > save > long reboot > boot menu (I see now CSM enabled) > setup > CSM is enabled.
*I cant disable CSM with RX 580
*This GPU works fine with i7-5820K
Config, EFI and screenshot in attachment
Bios not fixed my problem.
I cant still disable CSM with rx 580.
Temporally fix:
Bios:
4G decoding enable
Boot args: 0x2000 or 0x3000 (both works)
for now works fine Ryzentosh with dual boot and both cards rx 580 + GTX 1080.
EDIT:
more stable with 0x2000
