ASUS ROG STRIX Z790-F GAMING WIFI
candemasjor
6
intel i913900k
I can't open Install macOS missing internet
Intel(R) Ethernet Controller I226-V
Ventura does not work with our I225-V and I226-V ports unless we do the following:
  • Inject AppleIntelI210Ethernet.kext (Monterey version)
  • Add boot argument e1000=0
my computer internet does not work, AppleIntelI210Ethernet.kext either, but opencore usb is very bad
enable vtd
You probably need to spoof the controller. Find device path in Windows Device Manager.
my computer all that?
Details > Location Paths.
PCIROOT(0)#PCI(1C03)#PCI(0000)
ACPI(SB)#ACPI(PC00)#ACPI(RP04)#ACPI(D072)
ACPI(SB)#ACPI(PC00)#ACPI(RP04)#ACPI(PXSX)
check config.plist kernel\quirks
disableiomapper to false and reboot
if not work, apply DMAR fix
PciRoot(0x0)/Pci(1xC,0x03)/Pci(0x0,0x0) | Dictionary in DeviceProperties
Under this add
device-id | Data | 15F30000
You can screenshot and send here to double check.
VT-d isn't needed when using AppleIntelI210Ethernet.
Under this add
my computer internet doesn't work it's weird
