Ventura installation stuck with Log:Exitbs
vishnubud
10
Amd Ryzen 5 3600
Anyone help me to install Ventura in my and machine I'm attaching my EFI folder also
My configuration is :
Ryzen 5 3600
Asus B-450 M A Prime Board
Gigabyte Rx 570 4Gb
16gb ram
256 ssd
@vishnubud Try this OC 0.8.9 EFI, see if this gets Ventura running on your system.
Ohk brother i will try
Ventura 13.3 will not work until new kernel patches are released. People are working on it.
So can you help me to install Monterey
I used the efi for monterey but the same problem showing
tried Ventura 13.2.1 the same problem
(Log:Exitbs)​
EFI posted seems fine to me
Bios Settings?
4g on
CSM off
and all usual hack settings
I haven't see a your debug log so I do not know MAT value for your platform
you can try to enable also setVirtual map quirk (you have an early hang)
Reactions: Edhawk
Bios Settings?
4g on
CSM off
Updated My bios version and enabled 4g decoding
Now there is another problem showing
Lilu dev: @ found dead pci device GFX0
Bios Settings?
4g on
CSM off
Solved
Thank you Guys For the Support
Solution :
Bios Updated
Enabled 4g Decoding
Magic Number Doesn't match = Changed version Amdpowermanagment. Kext
lilu dev found dead pci device gfx0 = Changed version of Lilu. Kext
