Hey all! Any engineers here?
I've got a weird situation with my mobo.
I had 2x Sabrent Rocket 4.0 NVMes 1TB in my Monterey system, plus one 500Gb that had BigSur installed (old install, used as backup system.
I've decided to try and install the new Win11 build, so I've erased the smaller NVMe to install Windows on it (coz it won't install unless there are no macOS EFI partitions anywhere).
So, I've removed my hackintosh NVMes, secure-erased the 500Gb disk via BIOS, and then the dance began. Multiple things happened at once:
1. Sound started popping, but only if the rear motherboard socket is used, front panel works fine. The problem occurs regardless of the OS, so I assume it's a hardware issue.
2. One of the hackintosh NVMes died burying all the data, it doesn't initialize in the bios. I bought a Samsung 950 Pro to replace it, stupid me. Now I have an expensive external SSD lol, can't use it with macOS.
3. I've noticed that my front-panel USB3 / USB3.2 interfaces began to fail. Sometimes I attach an external drive to a USB, and it either doesn't show up, or turns on and off rapidly.
Is my mobo dying?
MSI MEG Unify x570 (I know, not the best MB for hackintoshing, I'm gonna replace it soon with an Asus one).
Is my mobo dying?
