Install MacOS Lenovo Legion 5 AMD Laptop
kevini
Hallo, have any chance to install MacOS on my laptop? (need for Xcode)
LENOVO Legion 5 15ACH6H
Specs:
CPU: AMD Ryzen 5 5600H
GPU: RTX 3060
The RTX 30560 is not supported in any version of macOS. So I would say no you don't have much of a chance of installing macOS and having a usable system. The graphics will be glitchy and possibly unusable, as the system lacks a supported GPU.
sladewatkins
I happen to have a GTX 1650, with the same CPU actually (how I came across this thread, I was interested in getting macOS running on my laptop (assuming it was even possible), but my laptop can turn off the dedicated GPU and just use integrated.
Now, my question is, does the iGPU on the Ryzen 5 5600H work, and if not: could it hypothetically work if a driver was built for it?
Unfortunately the integrated AMD IGPU doesn’t work in macOS.
You can both have a look at using WhateverRed, which aims to get AMD Integrated GPUs working in macOS.
It is a work in progress but probably the best bet for getting an AMD IGPU working.
MinhHoangg
I have an R5 5600H and Rx6600M with mux sw. Can I install Hackintosh on it
