Big Sur hackintosh OCB: StartImage failed - Aborted
jakuza622_2
Help please
OLD PROBLEM
12:171 00:029 AAPL: #[EB|RH:pF] usr\standalone\OS.dmg.root_hash
12:200 00:029 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.x86legacyap.im4m">
12:229 00:029 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
12:261 00:032 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
12:290 00:028 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
12:319 00:028 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
12:348 00:028 AAPL: #[EB|LOG:DT] 2022-08-10T20:08:12
12:377 00:029 AAPL: #[EB|LOG:EXITBS:START] 2022-08-10T20:08:12
22:409 10:032 OC: Boot failed - Aborted
25:490 03:080 OCB: StartImage failed - Aborted
NEW PROBLEM
08:415 00:019 AAPL: #[EB|SB:SBGMFNS] x86legacyap.im4m
08:434 00:019 AAPL: #[EB|RH:pF] usr\standalone\OS.dmg.root_hash
08:454 00:019 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.x86legacyap.im4m">
08:474 00:019 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
08:497 00:022 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
08:516 00:019 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
08:536 00:019 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
08:555 00:019 AAPL: #[EB|LOG:DT] 2022-08-10T20:58:47
08:575 00:019 AAPL: #[EB|LOG:EXITBS:START] 2022-08-10T20:58:47
My system
GPU: Amd radeon graphics
CPU: AMD Ryzen 7 4700U
8 gb ram
laptop hp
model:15s-eq107ur
  • opencore-2022-08-10-205807.txt
Sorry, but your Integrated AMD Radeon Graphics are not supported in macOS. Never have been and never will be supported.
You need a system with a discrete graphics card that is compatible with macOS. For a laptop to run macOS that means it needs an RX5000 or RX6000 series dGPU, and even then it is not certain you will be able to run macOS with any consistency.
No, you can't.
Moozuki
Exact same reason, no supported GPU.
