Threadripper, RX 6900 XT, Ventura 13.0 installation fail
Cosmin
39
Hello,
I currently have Big Sur 11.7.1 installed on a SSD.
I prepare a new EFI for Ventura installation, following Dortania guide, and the computer reboot itself after some time from boot.
I currently use OpenCore 0.8.6 - debug version, but I tryed before with 0.8.5. with the same results.
I attach EFI and debug file.
Please help, thanks.
and npci=3000
take the time to read carefully the dortonia guide, because you have a threadripper
@Cosmin
I advise you to go here. This is very specific to the Trx40 platform.
Here
Why is your Mmiolist half disabled?
If this is your values, all 16 values should be enabled (True)
Max Kernel (Patch) values should all be 22.99.99
These are remarks at first sight
@Cosmin
Here
Thanks Arrakis. I'm already check and test...
I see you also have Threadripper CPU. Could you share your EFI with me, please? Thanks
@Cosmin
It is available Here (first post).
It is under OpenCore 0.8.5 works under Ventura
Do you mean that macOS boots fully and then reboots? Or that it reboots at some point in the boot process?
no
he has or he seems to have same problems some MSI x570 users have had with OS greater than Big Sur
it is a second case which happens on trx40 boards (always Asus as manufacturer)
no
I have also issues with MSI B550 and Ventura.
With Big Sur works perfetly, but I try to boot macOS installer to install Ventura and reboot.
I haven“t lastest update bios for my motherboard.
