Is my computer compatible with MACOSX?
Deleted member 19055
AMD Ryzen 3 PRO 2300U
Hello
I'm just curious if my HP Elitebook is compatible with the latest version (or any version) of MAC OSX, my specs are bellow :)
If it is even possible to install MAC OSX where do I start?
HP Elitebook 745 G5 - Running x64 Windows 10 Pro
AMD Ryzen 3 PRO 2300U w/ Radeon Vega Mobile Gfx 2.0 GHz
AMD Radeon (TM) Vega 6 Graphics (integrated)
8GB DDR4 RAM
256GB SSD M.2 NVMe
Hello
8GB DDR4 RAM
256GB SSD M.2 NVMe
I do not believe it will work, some people have had luck with certain integrated gpu laptops, but not this model from what I seen. If you did get something running, it would be without GPU acceleration and would be useless and laggy at best.
