[Solved] New to Ryzentosh: [LOG:EXITBS:START] Error
Pgranix
46
13
Ryzen 7 3700X
Without a doubt I'm missed something. Been following Dortania's guide. Any feed will be helpful.
Hello,
Did you set the core count in the kernel patches correctly and enable ProvideCurrentCPUInfo?
Hello,
I used OC Gen-X 3.3.2 and set the cores to 8. Does the correct core count have to be set in the kernel patches in addition to setting in OC GenX? I will have recheck the config.plist for ProviderCurrentCpu. This setting was not mentioned in Dortania's guide, i believe.
Much obliged!
Much obliged!
If you're unsure feel free to upload the config and I'll check it.
Going over Dortania again, I completely missed modifying the "algrey - Force cpuid_cores_per_package" patches. Also, I had to add in "ProviderCurrentCpuInfo" in Kernel/Quirks.
U da bst! Thanks.
Reactions: Shaneee
Alright, I though I had it this time. Same error. I think it maybe my BIOS. I had just updated it before setting out on the Rzyentosh train. So, I'll take you up on your offer. Here is my config.plist.
Thanks.
Carefully reviewed different EFI's people have that were relevant to my system against my own config.plist. After many days, I realized that the the SSD I had in my system reserved for installing Ryzentosh, I was formatting as Journal extened instead of APFS.
