How Can I Remove Unused Open Core Picker Options?
sumeetxolt
10
India
webshade.in
I just upgraded to "Monterey" Yesterday and I can see a lot of options in Open Core "Picker" how do I remove Them? I believe they are from the "tools" folder under EFI/OC/Tools
I used EFI Available Here by user OG Nerd
My Specs
Motherboard: Gigabyte B450M-DS3H
CPU: Ryzen 5 3600
GPU: Gigabyte RX 550 4G
RAM: 16GB Corsair Vengeance DDR4 3200
NVME: WD Black 500GB
NIC: REALTEK
WIFI: FENVI T919/BT4.0
Opencore: 7.7
MAC OS: MONTEREY 12.5.1
Options can be seen in Screenshot, I just want to have macOS, Reset NV Ram, Recovery. That's it.
My Specs
CPU: Ryzen 5 3600
NIC: REALTEK
Opencore: 7.7
Remove the unused driver and tool entries in your config.plist and you can also use the HideAuxilary quirk. Then if you need to reset NVRAM or use another driver you can hit the spacebar at the picker screen and they will show up.
Reactions: Edhawk
