[Update OC 0.5.9] Ryzen 5 3600X, Gigabyte Aorus Pro X570, Sapphire RX580 8GB Pulse, Catalina 10.15.5
Vlad Vovk
Ukraine
Setup:
Motherboard: Gigabyte Aorus Pro X570
CPU: AMD Ryzen 5 3600X
GPU: Sapphire RX580 8GB Pulse
Memory: Crucial 16 GB (2x8GB) DDR4 3200 MHz Ballistix
Storage: WD Black SN750 nvme M.2 250GB , Samsung EVO 970 plus nvme M2 500GB (Win10)
Case: NZXT H510
MacOS: 10.15.4
OpenCore: 0.5.7
SMBIOS: iMacPro1,1
Kexts:
AppleALC, Lilu, SmallTreeIntel82576, VirtualSMC, WhateverGreen, AMDRyzenCPUPowerManagement, AppleMCEReporterDisabler, NVMeFix, SMCAMDProcessor
Drivers:
ApfsDriverLoader, HfsPlus, OpenCanopy, OpenRuntime
ACPI:
SSDT-EC.aml
Working
All
Not working
microphone
Sometimes my volume goes up or goes down. Sometimes it does not work for 1 sec and after this work
how can I fix it?
I use boot-args alcid-1
Reactions: markusdresch
Is sleep working for you?
Also I am pretty sure you don't need AppleMCEReporterDisabler. I am on an X570 Elite with iMacPro 1,0 SMBIOS and it is not needed for me.
Reactions: Vlad Vovk
Yes, sleep is working. It happened when I add AMDRyzenCPUPowerManagement and SMCAMDProcessor kekts to my build.
About AppleMCEReporterDisabler, okay I will remove it)
It is my first hackintosh, and I add all from the guide)
Hi!
Do you have any USB devices plugged into the motherboard when putting your device to sleep?
Thanks for the EFI, but sleep is not working for me. I suspect the FENVI WIFI/BT card to be the problem since it uses an internal USB2 port.
@JanHappy2000 I could fix sleep with my Intel AX200 after setting the internal USB port from internal to USB 2
