Ryzen 7 5700X—ASUS Prime A320I-K, Ventura 13.1, OC 0.8.7
craighazan
424
257
63
NY
Ryzen 7 5700X
screen-shot-2022-05-21-at-1-48-45-am-png.547999
AM4G5 (Naked) started in November 2021 after reading this article,
I thought this would be a good time to create a budget AMD build but using a brand new Ryzen 5000 series processor. It was a choice between Gigabyte or ASUS as they were the only confirmed motherboard manufacturers to have released the 'Unofficial' BIOS update to support Ryzen 5000 series. After some research I chose the A320I-K from ASUS, pretty sure it's the smallest 320 motherboard at 170mm x 170mm, rich feature set and a well thought out, I just wish they stacked an M.2_WIFI slot under the M.2 M key socket like I have on a H110MSTX board.
SPEC
AMD Ryzen 5700X 8-Core Processor (8Cores/16Threads @ 3.4 GHz Single Core 4.7 GHz Multi Core 4.6 GHz)
AMD Wraith Spire
ASUS Prime A320I-K BIOS 6042
Sapphire Pulse RX 580 8 GB
Corsair Vengeance LPX 16 GB (2x8GB) DDR4 3200
Western Digital Black SN750 500GB M.2 NVMe
EVGA 500 W1 500W Power Supply
Power Mac G5 (Mid 2004)
BIOS
Make sure you have the latest BIOS on your 320 motherboard before installing a Ryzen 5000 series processor. 6024 and 6042 are the official releases, 5862 is the 'unofficial' release from November last year.
SETTINGS
Ai Tweaker > Memory Frequency > DDR4-3200MHz (matches my Corsair Vengeance LPX frequency)
Advanced > SATA Configuration > SATA Mode Selection > AHCI (Default)
Advanced > USB Configuration > XHCI Hand-off > Enabled
Advanced > PCI Subsystem Settings > Above 4G Decoding > Disabled (using the boot-arg npci=0x3000)
Boot > Boot Configuration > Fast Boot > Disabled
Boot > CSM (Compatibility Support Module) > Launch CSM > Enabled (Dortania says disable, I have it enabled)
Boot > CSM (Compatibility Support Module) > Boot Device Control > UEFI only
Boot > Secure Boot > OS Type > Other OS
EFI
BENCH
Screen Shot 2022-05-31 at 10.58.53 PM.pngScreen Shot 2022-05-31 at 11.13.14 PM.png
what exactly tool you use to generate the specific efi? thanks
The tool I use is called HackinDROM, my EFI that I use on this build, has been uploaded to HackinDROM. All you have to do is pick the number of cores, enter SMBIOS and download, simple!.
(y), I also buy AMD Ryzen 5700X to build a hackintosh
It’s a really good processor, insanely fast on a 320 chipset and very quiet.
Successfully updated my AM4G5 to Ventura Beta 5 through System preferences, OpenCore 0.8.4. Work still to be done in the "About This Mac" window.
Screenshot 2022-09-12 at 10.07.38 AM.pngScreenshot 2022-09-12 at 10.08.14 AM.png
  • Love
Reactions: Middleman
Updated Ventura to Public Beta 9 (22A5373b) through system settings, booting OpenCore 8.5. Under a Gigabyte in size, 717MB to be exact. One new surprise is the Ventura Screen Saver, very relaxing!. Just need to remove GB under Graphics to make my about box typographically perfect, how do I do that @Shaneee ?.
@craighazan You could use device properties in the config to rename the GPU to AMD RX 580 8GB. Removing the Radeon part will shrink it to one line.
Reactions: craighazan
I know @CaseySJ and Inaquim over at TMX86 use OpenCore Configurator, I usually work with just ProperTree and HackinDROM, it's a good way to get familiar with the config and found editing a breeze. First I copied my working EFI to the EFI partition of a 16GB USB stick, that's the one I'm working on in OpenCore Configurator. Not knowing what I was doing I somehow added my Device Properties to my config, which I think is good and confirmed in Hackintool. Removed 'Radeon' from the two properties inside the yellow box, but I'm guessing that's wrong!, because 'GB' is still widowed!. Help requested on next step please!.
Update; After some reading I realized I could just compile the aml from and have it injected instead. I still can't get something right though!.
The address on the SSDT is incorrect. WEG is renaming it as part of its patches. Send over the config you're using to test and the PCI output from Hackintool.
Thanks, attached. A couple of things I changed since the last update, removed all device properties from config, created new SSDT before adding GPU Spoof. Read that I didn't need to add all PCIe devices to my config, just the ones for GPU.
  • Love
Reactions: Shaneee
Hi. I will upload it when I get home later, or you can download it through HackinDROM. I updated it this week.
