Ventura - Gigabyte GA-320M-S2H - Ryzen 5 3600 - RX 570 4G
OG Nerd
284
101
43
56
Missouri, USA
Ryzen 9 5900X
Motherboard: Gigabyte GA-320M-S2H
CPU: Ryzen 5 3600
GPU: RX 570 4G
RAM: 16GB OLOy DDR4 3200
NVME: Plextor 256GB
NIC: REALTEK
WIFI: FENVI T919/BT4.0
Opencore: 8.8
MAC OS: VENTURA 13.1
What's Working... Everything but Sidecar
** UPDATED EFI FOR RYZEN 5 3600 & OPENCORE 8.8, KEXTS FOR VENTURA 13.1 **
*** DON'T FORGET TO ADD YOUR OWN SERIAL, UUID & ROM NUMBER UNDER PLATFORM INFO/GENERIC **
大佬你好,我的主板和你一样,就是你的配置有声音卡顿的问题。你也有这个问题吗?
Hello, boss. My motherboard is the same as yours, but your configuration is stuck. Do you also have this problem?
What CPU do you have? Mine works.
AMD cpus with integrated graphics are not really supported, they all will more than likely have sound issues like you are describing. Your best bet it to upgrade to a ryzen 5 or above and a discrete gpu
thank you very much, everything worked the first time except bluetooth, - launched it with BcrmPatch
asrock a320m-dvs r4.0 , AMD Ryzen 5 1600, Monterey 12.3.1
UPD: 12.4 update DONE
Reactions: OG Nerd
How are you enjoying the 320 chipset?, I just finished an Asus Prime A320I-K with Ryzen 7 5700X build. I upgraded from a Ryzen 7 1700, my first 8-Core processor and I loved it.
Reactions: OG Nerd
It works well. It doesn’t have pcie 4.0 nvme but that’s ok
Reactions: craighazan
Sadly no pie 4.0. But I'm happy with my WD Black SN750, boots from cold to login in 19 seconds.
Reactions: OG Nerd
Yeah, that’s great speeds.. look at it this way, that’s as fast if not faster read write speeds than an m1 Mac mini or MacBook Pro! My specrix is a lil slower but close.
The 320 chipset has amazed me, the latest BIOS 6042 22/05/13 AMD AM4 AGESA V2 P1 1.2.0.7, has Ryzen 5000 support and single core is impressive.
Reactions: OG Nerd
Just updated this EFI to run Ventura Official Release.... (Original Post)
Reactions: NIK2802
Thanks for the EFI. Worked for me and was able to install Ventura latest version. Only issue I have is in ABout my Mac, it shows my CPU as a i5 instead of Ryzen 7. Any idea how to adjust this? I don't know if it matters or plays any role in sleep/power management
Thanks again!
Reactions: OG Nerd
Thanks again!
You need to update the amd patches to an 8 core cpu in the config.plist… if you don’t know what I mean, pm your version of the EFI and I will do the changes for you.
I just Updated My system From 12.6 To 13.1 Using this EFI.
Everything Works, I can't figure out a way to use Continuity Camera. but everything else is perfect.
Specs Listed Below, if you have similar Specs. Use this.
1CPUAMD Ryzen 5 3600 3.6 GHz 6-Core
2MoboGigabyte B450M DS3H V2
3RAMCorsair Vengeance LPX 16 GB (2x8)
4SSD For FCPWD Green 240 GB 2.5" SSD
5NVMe For OSWD Blue SN550 500 GB M.2-2280 NVME
6HDDToshiba P300 2 TB 3.5"
7HDDToshiba P300 2 TB 3.5"
8GPUGigabyte Radeon RX 560 - 1024 4 GB
9CaseThermaltake S100 Snow Edition
10PSUCorsair VS550 (2018) 550W
11WNAfenvi FV-T919 802.11a/b/g/n/ac WIFI Card
12FansRedgear 120 mm Fans 3-Pack
My Request to OP is that He/She should keep updating the EFI Provided, since it has been of tremendous help.
Reactions: OG Nerd
Just updated EFI to Opencore 8.8 and updated kexts. (See original post)
I've updated to 13.2.1 and I feel like my system is running slower. have you updated @OG Nerd
I am no longer using this machine, sorry. (I had to rob the video card from it). BUT, make sure you update your AMD patches in your config.plist file. That is the only thing off the top of my head that would make it slow down. Also, did you update all your Kexts as well?
