Monterey 12.3.1
CPU: AMD Ryzen 5 5600X @ 3.7GHz
GPU: Asrock RX 6600 XT phantom gaming OC 8G
RAM: 16GB Kingston FURY Renegade 3600 Mhz 16cl
Motherboard: Asrock b550 phantom gaming-itx/ax
Audio Codec: Realtek ALC1220/External audiocard m-track 2x2
Ethernet Card: Intel® I225-V 2.5Gb
Wifi+BT Card: WIFI 6 AX200
BIOS revision: 2.10
Fully working build, including ethernet, wifi, BT, sleep etc
For working Ethernet you need to use this patch for I225-V https://github.com/5T33Z0/Gigabyte-Z490-Vision-G-Hackintosh-OpenCore/blob/main/I225-V_FIX.md
This EFI use "Above 4g decoding" and "SAM" enabled in BIOS settings
Link to github EFI: https://github.com/tranquilitysmile/asrock-b550-phantom-gaming-itx-ax-opencore
