Ryzen 5 3600 + GTX 1060
LukeStarGeek
Hi. Can I install macOS on this setup (Ryzen 5 3600 + GTX 1060) even if the CPU doesn't have integrated graphics card? Will this work during the installation without web drivers?
Thanks
Yes it will work. You may need to use the boot arg nv_disable=1
LukeStarGeek
OK, thank you! I have spent hours on the internet without getting a proper answer. So I can install macOS and then install the web drivers?
teootoledo
Thanks
Hi! Could u share your config plist? Please
