No Wifi/Bluetooth/Ethernet on ASUS PROART X570-CREATOR WIFI
amdosxuser9
Hi, I have a ASUS PROART X570-CREATOR WIFI with a 5950x which is working well
What's not working is the Ethernet WIFI and Bluetooth. I'm currently connecting online using a Thunderbolt 4 to ethernet adapter
I installed the following Kexts from OpenIntelWireless:
AirportItlwm.kext
IntelBluetoothInjector.kext
IntelBluetoothFirmware.kext
But they didn't work and were causing crashes. Anything else I can try?
Many thanks
Did you use the kext specifically for Big Sur? Each version is for a different version of macOS.
amdosxuser9
amdosxuser9
I didn't use HeliPort, that worth a try ?
edit: hmm no
You could swith from the Airport version to just itlwm. See if it makes a difference. The issue could be with USB as that's what the BT will run on. Is your USB map done to include the internal header the BT is on?
amdosxuser9
Hmm I haven't touch the USB I think. All USB and T4 ports work perfectly so I didn't want to touch it. Is that something I should have done ?
Does either WiFi or BT work at all? Do they show in System Information or Hackintool?
amdosxuser9
Nothing for Bluetooth:
Something here under WIFI:
Neither are working though. Also ether net not working - only via a thunderbolt 4 adapter
amdosxuser9
All works in windows - so not a hardware issue
Are you aware the kexts aren't in your EFI or config you've uploaded? Did you add them to the wrong EFI?
amdosxuser9
That’s right, I did trying putting these in
AirportItlwm.kext
But the system kept crashing
Try with just WiFi for now. Narrow it down to which one is causing the issue. You could also remove IntelBluetoothFirmware.kext and use BluetoothFixup.kext. It's intended for Monterey but may be of use here.
amdosxuser9
I started with installing only AirportItlwm.kext and it crashed
Initially it booted, WIFI didn't work, so I plugged in the Ethernet cable, it went orange, then green at which point it crashed
It's sounding more like a LAN issue tbh. Disable the LAN controller in the BIOS to test. It's possible Apple are chaning stuff in Big Sur like they are in Monterey. The same thing happens to me on Monterey with my LAN enabled.
amdosxuser9
Ok I'll try that, thanks
amdosxuser9
EDIT: Turns out I forgot to do an OC Snapshot before restarting!
WIFI is now working! Thanks
Bluetooth is still not working yet:
Anything else I can try with that? Many thanks
Sharky
Hi,
I m faced with a similar issue: I don’t get BT/WI-FI/ETH (both the 10G/2.5G NIC)working.
would you mind sharing your efi? Having the Wi-Fi working would be of great help!
Which OS/ bios are you on?
amdosxuser9
Secret for me was to use Heliport
on 12.2.1
Here are my Kexts:
Hope that helps
amdosxuser9
Using 12.2.1
Here you go. Don't forget to download Heliport and use a bluetooth dongle
You'll need to add in SystemSerialNumber & ROM with your own
