Redownload the latest OpenCore and create a new config.plist. Ive noticed using OpenCore configurator causes this issue. Make sure to use only plist editor, Xcode, ProperTree etc to modify your config.plist.
Also use the attached link to check your config for issues
Hello!
I managed to correct. For some reason, these 3 entries that appear as Block should be Delete. I didn't use configurators, but there was still this difference. Anyway, now it worked. Thank you.
I have these messages too (also built from scratch, no configurator) but I don't quite understand "these 3 entries that appear as Block should be Delete" - what did you do to your config.plist specifically?
