yes, I installed the Nvidia ´s patcher. So, I have to reinstall the OS(12.1) and then patch again. Is that correct?Did you make changes to the system partition to enable the GT 710? If so you'll need to download the full installer app to update as the APFS seal will be broken, then any modification will need to be made again.
Thanks again @Shaneee for your help...Yes you'll need the full installer which you can get here for 12.1, http://swcdn.apple.com/content/down...ebasc92qkw2iv44e1j9pv09f/InstallAssistant.pkg
Run the pkg and it'll add the App into your Applications folder. Run that and it'll update the system.
thanks. I will tryYou hadn't updated to the newest kernel patches. I've updated the EFI to OC 0.7.7 along with the kexts and removed the unnecessary kexts too. Not sure what you've got going on with your ACPI patches so I've left that as is. Give this a go.
I'm sorry Shaneee. I gave you the wrong EFIthanks. I will try
Maybe cause I mixed them. The intel is from pastrychef on the other forum.From an Intel system but it has AMD specific kexts and the kernel patches??? Either way the one I uploaded will work on your system.
ShaneeeFrom an Intel system but it has AMD specific kexts and the kernel patches??? Either way the one I uploaded will work on your system.
I´m on 12,1 with OC 0.7.5, ok?GT710 no longer works on newer versions of macOS. That's most likely the issue.
It's not an OC issue. Apple dropped support for Kelper in Monterey.As of Monterey beta 7, Kepler is unsupported. It is still supported in macOS Big Sur.
