Hello. I have MacOS 10.13.3 installed on my computer, but I can't put any updates there. Software updates, such as Safari from the Appstore, are installed without problems, but updates to the system itself are not successful. I couldn't update the installed MacOS 10.13.3 even to 10.13.6. When the computer restarts after running the update installer and in Clover I select "Boot Install MacOS From MackintoshHD" the download stops at "End RandomSeed". If you select "Boot MacOS from MackintoshHD", the update is not installed. There is probably something wrong with kernel or with Boot Args. Please write the most detailed instructions on how to update the system from 10.13.3 to 10.13.6 and from 10.13.6 to Mojave.
I can give you more information if you need it, just let me know.
I used translate.yandex.ru to translate this text into English
My computer:
CPU: AMD Ryzen 5 1400
GPU: MSI GeForce GTX 1050
memory: 8GB
SSD: 230GB
P.s I made a mistake when choosing the topic where I wrote the post.
My computer:
memory: 8GB
SSD: 230GB
