Found a similar thread upon ressearch, but unresolved: https://forum.amd-osx.com/index.php?threads/problem-with-dual-alc1220-audio-codecs.1420/
Hi all,
I've been having this problem since I started this Hackintosh on Big Sur & Catalina. Now I use Monterey 12.1 (Specs in my signature).
macOS audio is definitely working perfectly with AppleHDA (No VoodooHDA), until I reboot into Windows 10 (same SSD), then if I reboot into macOS later, the volume up/down animation will play as normal, but no sound at all. The sound is lost until I reboot into Linux Mint it appears and access macOS again, audio will return.
boot-args: keepsyms=1 debug=0x100 agdpmod=pikera npci=0x2000 alcdelay=1000
Previously, I used alcid=7 with success in the bootargs, and so I decided to improve it following the Dortania guide and removing the bootarg ( https://dortania.github.io/OpenCore...al/audio.html#making-layout-id-more-permanent ). This has been successful. I also managed to add the boot chime to the picker successfully. What I can tell is that the boot chime will work, until I reboot into Windows, then when I reboot again, I'll lose the boot chime (Actually it does play, only garbage) and will also lose all audio in macOS... that is until I reboot into Linux again. It seems that the audio is breaking very early on in the boot process then if the boot chime doesn't even play.
Any clue? Do I need to provide my full config.plist / ioreg ?
Much appreciated,
<dict>
<key>DeviceProperties</key>
<dict>
<key>Add</key>
<dict>
<key>PciRoot(0x0)/Pci(0x8,0x1)/Pci(0x0,0x4)</key>
<dict>
<key>layout-id</key>
<data>
07000000
</data>
<key>alctsel</key>
<data01000000</data> (As recommended here, as this is the same problem: https://dortania.github.io/OpenCore...html#applealc-not-working-from-windows-reboot )
</dict>
</dict>
<key>Delete</key>
<dict/>
</dict>
</dict>
Hi all,
Much appreciated,
<dict>
<dict>
<key>Add</key>
<dict>
<dict>
<data>
07000000
</data>
<key>alctsel</key>
</dict>
</dict>
<key>Delete</key>
<dict/>
</dict>
</dict>
