Hello,
2 years ago I successfully setup a High Sierra with Clover.
However when I changed my GPU from R9 280x to my current RX 5700XT, as expected I could not boot anymore.
So I gave up for half a year and now I am trying to install a ryzentosh with Big Sur. I followed the Dortania guide:
I made an installer on windows added the com.apple.recovery.boot, EFI, folder, kexts, etc etc. And when I double checked everything, I booted from the flash. However, it detected only the Windows and there was no other option. I thought I have skipped a step, so I went through them again, and I didn't change anything as everything seemed ok. Tried again, same thing.
So a couple checks again, and then I decided to try Catalina -> same story. As I saw that Big Sur and Catalina for me are with the same problem, I tried again with Big Sur, same checks added the kexts - no result, with the difference that I forgot to set the ScanPolicy to 0, sO i saw the openshell.efi as option.
I have been doing that for the last 5 days, researched other people's same problems but I just can't get it fixed. I modified the plist file with possible fixes but unfortunately nothing happened. Black screen with no logs or something like that - the only logs I have are from the opencore and each is 256KB but it is empty with : 0000 0000 0000 0000
What am I doing wrong?
My system is:
Ryzen 5 2600 4.0ghz oc
Asrock AB350M Pro4 - BIOS version P5.10
2x8gb 3200mhz corsair vengeance
and 3 ssds which imo is irrelevant to specify.
I am attaching the config.plist file and a picture of my usb structure.
My system is:
