Monterey on AMD Ryzen 5 3600X, NVIDIA GeForce GTX 1060, ASRock X570 EFI CONFIG OC
stefek90
AMD Ryzen 5 3600X
Helle Friends.
i need help wio´th my Configuration.
My PC:
AMD Ryzen 5 3600X,
ASRock X570
Wich kext i need?
EFI Folder available?
config.plst?
Manual to Install Step by Step?
I will pay for it with Paypal.
Please Help me.
Thanks!!
gtx 1016 can only be used for High Sierra, you can search for 3600x EFI on github and install webdriver after entering the system.
Reactions: stefek90
GTX 1060 meens that is not metal Grapic Card Right?
the correct cpu + motherboard should ensure that you can successfully enter the system
I recommend you sell gtx1060 and buy rx 550 or new
