OC halt upon [EB|#LOG:EXITBS:START]
DEXTER-AMD
Hi there, I still hang on [EB|#LOG:EXITBS:START] by booting OC.
I also even run the debug of OC and uploaded the generated textfile herefore.
Hopefully someone could help me out of it. I now start to read and try to comprehend the
MIMO Part (DevirtualiseMmio). Your support and any advice would be really great. Thanks a lot.
My system specs:
Mainboard A68HM-PLUS by ASUS
16 GB Memory
AMD A10-6790K APU with Radeon(tm) HD Graphics
Graphics Card Device: NVIDIA GeForce GTX 960 4 GB
  • opencore-2021-10-27-004014.txt
  • opencore-2021-10-29-014541.txt
DEXTER-AMD
My system specs:
16 GB Memory
Hi I stillstuck on [EB|#LOG:EXITBS:START]. Could someone help please?
  • opencore-2021-10-31-082212.txt
Try this,
DEXTER-AMD
Try this,
🇩🇪 🎶Bei mir bist du schön "Shaneee", please let me explain: :D Well I'm serious again!
Thank you very much for the effort and the modification on the config.plist.
Unfortunately, OC is still hang upon [EB | LOG: EXITBS: START]. Can you also get it from the OpenCore.txt debugfile (attached) on what it could be or even what it cause of not going any further? Because, I'm already fed up with „EXITBS: START“. However, I would be very grateful to get any empirical advice and at the end, I don't really want to give up… not yet:cool:
So, I believe I’ll see it through, with you. I think I'm still patient, am I? Anyway, 🧙‍♀️ 🔮 If I had a chance... mh to make it work? I know my hardware isn't the best, but I think it would be somehow possible, wouldn't it ?!:unsure::coffee::)
  • opencore-2021-11-04-111223.txt
Using the same EFI try making a High Sierra installer. You won't be able to go higher than that with your GPU anyway.
DEXTER-AMD
The truth doesn't hurt. Thanks very much :D I really appreciate your work very much. Keep it up. :cool:
(y)
