Stuck At non ejectable disk image
DAFFY
119
6
18
Ryzen 9 3900X
hi guys, after some searching I found a EFI for my setup but its not the latestOpenCore, I think its 0.6.0 and I'm now stuck at NOTE: administrator is creating non-ejectable disk image. I'm hoping that someone can help me on this. I've attached photo and EFI
That's most likely the issue. Follow the guide and make your own EFI and see how it goes. We are here if you need help.
Reactions: DAFFY
Hi Shaneee, just went through the process of creating a 0.7.4 EFI folder and I just get a black screen. I tried using SSDTTime but I couldn't get it to dump my files, I even tried downloading the script files that were meant to fix the problem but had no luck there either. so I tried using a pre built SSDT. I've attached my EFI Folder. hopefully you or someone can make some sense of it because I'm stuck.. Thanks..
The 'Force cpuid_cores_per_package' patches are wrong. You've changed the Find value instead of the Replace value. Copy the patches in again and redo those ones.
Hi Shaneee, ive redone the patches and still no picker list, could you take another look please at my Uploaded EFI version 0.7.4. Thanks
What do you mean by no picker list... Can you share an image.
Hi Shaneee, I would share an image of the screen if there was an image to show. after booting all I get is a black screen. No OpenCore GUI or anything
Is CSM disabled in your BIOS?
Yes CSM is disabled in the BIOS
Try with this,
Thanks for the EFI but still just a black screen
Target was already set your EFI so you'll see a bunch of txt files from each boot. Remove these then try boot with this EFI and upload the txt file it generates. This is a debug EFI.
Hi Shaneee, I've just tried the debug EFI and the text file is empty
Hi Again Shaneee I'm still stuck with this EFI. Would it be beneficial to try and create a Clover EFI instead of OpenCore.?
That's strange... The target is set to 67 so it should at the very least output something even if it's not a debug build.
            <key>Target</key>
            <integer>67</integer>
