macOS Installation error after successful boot
ehsan
I followed https://dortania.github.io/OpenCore-Desktop-Guide/AMD/zen.html procedure.
At the first I had issue with the PCI which has been fixed by npci=0x2000 flag.
finally I got to the 10.15.4 installation.
I done the the first installation part but after first reboot I'm getting macOS Installation Couldn’t Be Completed error. I saved the logs from the error message and I've attached that here.
I tried lot's of flags and drivers but nothing has helped me so far.
I've seen some threads at Reddit about the problem with MSI Radeon cards and installed the MAC via a different card and then swapped that back. is that the case?
Is there anyway to pass this installation step as I don't have any spare card?
I've used lasted version of OC (0.5.8), drivers and kexts.
Thanks
My Rig :
Asus TUF X570 Plus Wifi
Ryzen 3700X
MSI 5700 Gaming X
RAM 32GB GSkill 3200
SSD WD SN750 500GB
Update 27 May 20: I tested that with 10.15.3 installer and same issue.
With 10.15.5 Installer I got kernel panic that I think that's not supported by OC yet.
Update 28 May 20: Error image attached
  • Installer Log 26-May-2020.txt
ehsan
I still have the issue. Can anybody help me with that?
A few things looking through your config.plist:
Unless you patched your DSDT remove it. You are already setting the layout in the boot-args, remove all DeviceProperties. Also, you have a lot of kexts added I never heard of, maybe try with only the basic ones (Lilu, VirtualSMC, WhateverGreen). The NullCPUPowerManagement one you don't need since you've already enabled DummyPowerManagement.
Also try different USB ports.
ehsan
Thanks for your response.
Firstly I started with a clean config file and added them all one by one to find the workaround, but nothing changed.
I will try again with a clean basic config on a different USB port and will update here.
ehsan
I've done all the steps again with a clean config.plist which is attached.
I used a brand new USB 3 flash drive this time on a different USD port.
As before the first boot everything went well and I formatted the drive as APFS and installed the Catalina. It rebooted for the second part and the booting process is fine but at the first of MacOS Installation was fine I got similar MacOS Installation error.
My problem is not in the boot process but is some issue in the installation part!
I'm looking forward for your solutions.
  • opencore-2020-05-28-060103 - first boot.txt
  • opencore-2020-05-28-062758 - second boot.txt
  • Installer Log 28-May-2020.txt
Did you notice this right at the top of the log? 08:525 00:015 OC: Failed to add ACPI SSDT-EC-USBX-DESKTOP.aml - Invalid Parameter
ehsan
Yes, I removed that on next reboot but same result.
I've found this error that I think could be relevant as just after that Crash Log Viewer launched.
Do you think the issue could be with my nvme SSD?
May 28 07:21:34 iMac-Pro OSInstaller[631]: X file:///Volumes/MACOSX/: Missing SystemVersion.plist
May 28 07:21:34 iMac-Pro Unknown[650]: Launching the Installer Crash Log Viewer
I'll try to install again on a SATA drive.
ehsan
I tried with SATA and even USB drives but same error.
The crash seems to be GPU related. Try booting with the boot arg -wegnoegpu
You can remove it once installed.
ehsan
Thanks Shaneee for your advice.
I tried your recommended arg to disable egpu but I got the attached error message.
  • opencore-2020-05-29-115244.txt
Something else must have changed. Only adding the boot arg wouldn't have caused that error.
ehsan
Thanks!!!
You are completely right about both errors. the second error was because I was choosing another hard disk which had a faulty install before.
and
-wegnoegpu
fixed my boot issue. But I need to remove that after second boot.
Now everything is working perfectly on my mac. All USB ports. Audio. HDMI and even onboard Bluetooth except for WiFi which is a well-known issue with Intel Wireless cards.
Performance is similar to windows on both CPU and GPU.
Amazing!!! Thank you for your great advice :)
portekizli
Thanks!!!
and
-wegnoegpu
Hi first! I have similar hardware and I encountered the error you encountered. However, I did not fully understand its solution. I used the -wegnoegpu argument, but it gets stuck on the black boot screen. I would be glad if you explain in detail how you solved the problem. Thanks.
ehsan
Can you boot to the Mac Installer without -wegnoegpu argument?
