x570 Aorus Elite - 3700X - Red Devil 5700XT
AudioGod
AudioGod
If you are using the boot argument alcid=1 try changing it to alcid=7 instead, if that don’t work then stick your Efi on a usb installer and then try disabling WhateverGreen and see if it works better for you without it.
I say to put the EFI onto a USB installer just in case it boots to a black screen without the kext. Should actually work better without it though if the screen doesn’t go blank.
Check your IOReg for HDAU It might be named something else in which case a simple rename should fix it.
tatofuma
I have 69 on alcid at the moment. Try with 7
@AudioGod with alcid 7 no audio, not even motherboard outputs
I turn off whatevergreen, boot well, but no hdmi audio
AudioGod
OK try alcid=29 instead
Pulsar
Guys I point out that I too have had problems with the 5700XT HDMI / Audio. Then I solved with the motherboard audio and didn't care anymore.
tatofuma
Yes it is not a fundamental thing, the audio of the motherboard is fine (better with layout 3, it also recognizes the earphones inserted in the front panel).
I have read that using the display port the audio works, so I probably buy a dp-hdmi adapter.
AudioGod
@Pulsar I just plugged in a reference 5700XT and its outputting Audio to my Samsung TV via HDMI straight away. Same thing with my 6800 and previously my 6900 XT.
Thinking back to when I used a Gigabyte X570 Pro motherboard and then a Ultra it was the same deal with a 5700 XT
Theres a connection to this that I’m not thinking of here but it will come to me eventually…
AudioGod
Update - it’s your alcid number that’s causing it,
Looking at your motherboard it uses a Realtek ALC1200 codec, I have checked the support tables for you guys and one of the following layouts will be correct with the HDMI out and internal Outputs.
you need to try the following one by one until you hit gold
ALC1200 layout 1, 2, 3, 4, 5, 7, 11, 27, 28, 29
Pulsar
Soon I'll try to see if it works. Actually I'm fine with the AUX on the mobo.
Magical as always guys 🔥
tatofuma
I’ll test tomorrow
EDIT: don't work for hdmi audio. No problem, I will test with dp-hdmi adapter soon
codecex
Hi, anyone has tried to update to Monterrey? thanks!
