Kernel panic after 11.5.2 update
barmyman
5
Hello! I've had 2 random kernel panics after update to 11.5.2. Before this update everything was super stable and smooth. Any help would be appreciated. Info below.
mp_kdp_enter() timed-out on cpu 4, NMI-ing
mp_kdp_enter() NMI pending on cpus: 0 2 4 8 11 12 14
mp_kdp_enter() timed-out during locked wait after NMI;expected 16 acks but received 10 after 17255238 loops in 1800001480 ticks
panic(cpu 4 caller 0xffffff800f7c57d6): Kernel trap at 0xffffff800f7cee0c, type 14=page fault, registers:
CR0: 0x000000008001003b, CR2: 0x0000000000000000, CR3: 0x000000001b90a000, CR4: 0x00000000000406e0
RAX: 0x0000000000000000, RBX: 0xffffffc10c48bd30, RCX: 0x0000000000000004, RDX: 0xffffff800ff1f087
RSP: 0xffffffa0b1cf0e38, RBP: 0xffffffa0b1cf0f80, RSI: 0x0000000000000100, RDI: 0xffffffa0b1cf0e60
R8: 0x00000c0a4e20921f, R9: 0x0000000000000000, R10: 0x0000000000000000, R11: 0x0000000000000004
R12: 0x0000000000000008, R13: 0xffffff80104432c0, R14: 0xffffffa0b1cf0e60, R15: 0xffffffc10c48bd30
RFL: 0x0000000000010046, RIP: 0xffffff800f7cee0c, CS: 0x0000000000000008, SS: 0x0000000000000010
Fault CR2: 0x0000000000000000, Error code: 0x0000000000000000, Fault CPU: 0x4, PL: 3, VF: 5
Backtrace (CPU 4), Frame : Return Address
0xffffffa0b1cf0850 : 0xffffff800f68e04d
0xffffffa0b1cf08a0 : 0xffffff800f7d4e13
0xffffffa0b1cf08e0 : 0xffffff800f7c540a
0xffffffa0b1cf0930 : 0xffffff800f632a2f
0xffffffa0b1cf0950 : 0xffffff800f68d86d
0xffffffa0b1cf0a70 : 0xffffff800f68db63
0xffffffa0b1cf0ae0 : 0xffffff800fe9dc0a
0xffffffa0b1cf0b50 : 0xffffff800f7c57d6
0xffffffa0b1cf0cd0 : 0xffffff800f7c54bd
0xffffffa0b1cf0d20 : 0xffffff800f632a2f
0xffffffa0b1cf0d40 : 0xffffff800f7cee0c
0xffffffa0b1cf0f80 : 0xffffff800f7c4bab
0xffffffa0b1cf0fd0 : 0xffffff800f632bdd
0xffffffc10c48be50 : 0xffffff800f6a1074
0xffffffc10c48be80 : 0xffffff800f6e2870
0xffffffc10c48bea0 : 0xffffff800f6e71aa
0xffffffc10c48bef0 : 0xffffff800f6d56f5
0xffffffc10c48bfa0 : 0xffffff800f63213e
Process name corresponding to current thread: kernel_task
Boot args: npci=0x2000 alcid=2 -no_compat_check shikigva=144 busratio=44 chunklist-security-epoch=0 -chunklist-no-rev2-dev
Mac OS version:
20G95
Kernel version:
Darwin Kernel Version 20.6.0: Wed Jun 23 00:26:31 PDT 2021; root:xnu-7195.141.2~5/RELEASE_X86_64
Kernel UUID: FECBF22B-FBBE-36DE-9664-F12A7DD41D3D
KernelCache slide: 0x000000000f400000
KernelCache base: 0xffffff800f600000
Kernel slide: 0x000000000f410000
Kernel text base: 0xffffff800f610000
__HIB text base: 0xffffff800f500000
System model name: iMacPro1,1 (Mac-7BA5B2D9E42DDD94)
System shutdown begun: NO
Panic diags file available: NO (0xe00002bc)
Hibernation exit count: 0
System uptime in nanoseconds: 13239400189246
Last Sleep: absolute base_tsc base_nano
Uptime : 0x00000c0a89befa2a
Sleep : 0x0000000000000000 0x0000000000000000 0x0000000000000000
Wake : 0x0000000000000000 0x000000138bfa0498 0x0000000000000000
My specs:
Ryzen 3700x
MSI B350 Gaming plus
32 gb DDR4 G.Skill Value CL15
Vega 56 Asus Strix
You can remove these boot args for a start,
-no_compat_check busratio=44 chunklist-security-epoch=0 -chunklist-no-rev2-dev
-no_compt_check is only for forcing macOS to load on an unsupported SMBios. You should use MacPro7,1 or iMacPro1,1
Thanks! Removed unnecessary stuff, but i solved this problem "original mac way" - reseted NVRAM. The problem seems to went away.
Reactions: Shaneee
