Ocs no schema for skip 1 at 6 index
diniket
12
AMD 2700X
This problem slow me boot [emoji848]
Thx
Inviato dal mio SM-G991B utilizzando Tapatalk
Your config is either misconfigured or doesn't match the version of OC you are using. Use ocvalidate to check your config. OCvalidate comes with OpenCore when you download the RELEASE zip.
marco@RyzenAMDdiMarco ~ % /Users/marco/Desktop/ocvalidate /Volumes/EFI/EFI/OC/config.plist
OCS: Missing key Skip, context <Patch>!
OCS: No schema for Skip 1 at 6 index, context <Patch>!
Serialisation returns 2 errors!
Completed validating /Volumes/EFI/EFI/OC/config.plist in 2 ms. Found 2 issues requiring attention.
So either ACPI -> Patch, Booter -> Patch or Kernel -> Patch is missing a Skip entry.
I added an entry under kernel-> patch-> 2 that was missing
now only an error remains, I checked under ACPI -> Patch, Booter -> Patch but the Skip voices seem to be present
Can you send your config? I'll take a look.
Here's where the error is. Skip 1 isn't valid. Skip is already there to remove the Skip 1 entry.
what program do you use to read the config? i use ProperTree, maybe there is a compatibility problem?
solved thanks, I did not read well, it was more on :)
other thing, I tried to compare the config with occonfigcompare and it returns me this:
# OC Config Compare #
Checking for values missing from User plist:
config.plist -> Misc -> BlessOverride -> From | To-Array - Empty: Skipped
config.plist -> DeviceProperties -> Add - Missing Key: PciRoot (0x0) / Pci (0x1b, 0x0)
config.plist -> NVRAM -> LegacySchema -> 7C436110-AB2A-4BBB-A880-FE41995C9F82 -> From-Array - Non-Dictionary Children: Skipped
config.plist -> NVRAM -> LegacySchema -> 8BE4DF61-93CA-11D2-AA0D-00E098032B8C -> From-Array - Non-Dictionary Children: Skipped
config.plist -> NVRAM -> Delete -> 7C436110-AB2A-4BBB-A880-FE41995C9F82 -> From-Array - Non-Dictionary Children: Skipped
config.plist -> NVRAM -> Delete -> 4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102 -> From-Array - Non-Dictionary Children: Skipped
config.plist -> NVRAM -> Delete -> 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14 -> From-Array - Non-Dictionary Children: Skipped
config.plist -> UEFI -> Drivers -> From-Array - Non-Dictionary Children: Skipped
config.plist -> UEFI -> AppleInput - Missing Key: GraphicsInputMirroring
Checking for values missing from Sample:
Sample.plist -> Misc -> BlessOverride -> From | To-Array - Empty: Skipped
Sample.plist -> NVRAM -> LegacySchema -> 7C436110-AB2A-4BBB-A880-FE41995C9F82 -> From-Array - Non-Dictionary Children: Skipped
Sample.plist -> NVRAM -> LegacySchema -> 8BE4DF61-93CA-11D2-AA0D-00E098032B8C -> From-Array - Non-Dictionary Children: Skipped
Sample.plist -> NVRAM -> Delete -> 7C436110-AB2A-4BBB-A880-FE41995C9F82 -> From-Array - Non-Dictionary Children: Skipped
Sample.plist -> NVRAM -> Delete -> 4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102 -> From-Array - Non-Dictionary Children: Skipped
Sample.plist -> NVRAM -> Delete -> 4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14 -> From-Array - Non-Dictionary Children: Skipped
Sample.plist -> UEFI -> Drivers -> From-Array - Non-Dictionary Children: Skipped
I have to do something?
thank you again
Yeah was the config you've uploaded. I use PlistEdit Pro. Just doubled checked on Windows too and it shows the same thing.
Anything that says Skipped when using OcConfigCompare can be ignored.
Reactions: diniket
