RT.GV booter-strict-xmlparser
diniket
12
AMD 2700X
I am attaching files, the system starts fine, no problems but I have a number of errors, can I ignore them or do I have to fix them? Thank you
The log looks fine. You don't need to use the debug version of OC and log the output. All that can be disabled. Will also speed up your boot.
How do I disable debugging? Thanks for your assistance 😄
Yes but you may have the debug release of OC too. Simply download the RELEASE version and replace the BOOT folder and OpenCore.efi and make those changes and should be good to go.
Reactions: diniket
Thanks, I did as you said, I don't notice excessive speed change on boot 😄
