Noob question! R5-3500X+GTX1050 High sierra
Ryan1218
I don't think the order matters anymore. Also it's a kext not a kernel :p
Hello, because High Sierra supported too less apps, so I bought a Power Color RX 460 2G and tried to install Big Sur. Sadly, Stuck on [EB|#LOG:EXITBS:START] kept happening to my computer. I tried to fix it following the troubleshooting guide separately (https://dortania.github.io/OpenCore...rnel-issues.html#stuck-on-eb-log-exitbs-start). But there was no any way(Booter, Kernel Patch and UEFI issue) helped me. And I cannot realize what setting made me fail because I had succeeded on installing High Sierra with the same setting( Bios, Booter, Kernel Patch and UEFI setting) . If you were available, might you help me fix the problem? Thank you so much for your reading! And this is my own EFI folder.
Ryan1218
Glad I could help.
Ryan1218
Sorry, could I bother you one more time? I have used my hackintosh well. However, the airdrop didn't work, even I had successfully drive WIFI and BT with the correct kexts( and I also tried other kexts of the older version). The shown inside the photo is my Ipad, but the other devices could't be detected. And when I click my Ipad, I cannot airdrop anything to my Ipad ,too. My WIFI card is AC3168 (intel).
You'll need AirportItlwm.kext for working AirDrop from what I can tell.
Ryan1218
You'll need for AirportItlwm.kext working AirDrop from what I can tell.
Yes, I have tried many versions of AirportItlwm.kexts these few days. However no one seems to help. Is there anything I go wrong? And really thanks again!
Did you add it to the config correctly? How isn’t it working? Does it panic?
Ryan1218
Yes, I added it to config correctly and my WIFI and bluetooth functioned well. But just airdrop functioned badly. When I click someone for airdrop, nothing just happened, no panic, no freeze,no restart, no shut down, just like I had not clicked any botton and nothing was functioning.
Did you use the correct kext for the version of macOS you've got?
Ryan1218
Yes, I get the Big Sur one. But just nothing happened sadly.
  • Sample.plist
Ryan1218
Apparently it's necessary to force load the IO80211Family kext, https://github.com/OpenIntelWireless/itlwm/issues/659#issuecomment-896535684
Attached is how to force it to load with OC.
Thank you for your reply! But sadly it failed. I have tried IO80211Family kext and IO80211FamilyV2 kext, and I had set my secure boot to default (or Mac pro 7.1). The airdrop just didn't work. But I saw other articles say AC 3168 is compatible for airdrop using AirportItlwm.kext, I am not sure where I get wrong.
I'm not sure what else to suggest. Never had any dealings with Intel WiFi/BT. You could open a ticket on the Itlwm GitHub.
Ryan1218
Still thank you for all you have done! I will tried it when being free. THANKS!
